Documentation for Users
2.0.6
Perception Toolbox for Virtual Reality (PTVR) Manual
If you have followed the previous "Getting Started" subsections,
and this includes having carefully read the IMPORTANT warning in the Install Python subsection about setting the Python Environment Variable PYTHONPATH,
then you should be able to display "Hello World" in your VR headset with the following script 10_hello_world.py :
...\Demos\Text\hello_world.py
import PTVR.SystemUtils
import numpy as np
import PTVR.Visual
import PTVR.Stimuli.Scenes
import PTVR.Stimuli.Objects
def main():
my_world = PTVR.Visual.The3DWorld()
my_scene = PTVR.Stimuli.Scenes.VisualScene ()
text = PTVR.Stimuli.Objects.Text ( text = 'Hello World !',
position_in_current_CS = np.array ( [ 0, 1, 1 ] ),
fontsize_in_postscript_points = 60
my_scene.place (text, my_world)
my_world.add_scene (my_scene)
my_world .write () # writes to .json file
print (".json file has been created.")
if __name__ == "__main__":
main()
PTVR.SystemUtils.LaunchThe3DWorld("Jane Doe")
Demos Path of demos: ...\PTVR_Researchers\Python_Scripts\Demos\Text\
| Python file | Description |
| 10_hello_world.py | this demo contains the code displayed above.
